Can a r005 resistor stop a pc from turning on
got a 980 ti from a mate that said it just stop working so i took it off him and found the one of the r005 resistor has a crack down it as well as missing the two 00 on the front writing i have include a photo of were it is
この質問は役に立ちましたか?
4 件のコメント
Hi,
It might depend on what else is damaged that you can't see. Resistors rarely fail without a reason.
Is the PC giving error beeps or messages about a video problem on startup or just refusing to start?
If refusing to start with the card plugged in it could be draining too much power on its supply rail which is being detected by the BIOS.
Does the PC start without it plugged in using a different video card but one that uses the same PCI slot?
Not sure what you mean by "missing the two 00 on the front writing"
jayeff さんによる
pc dose boot fine with a hd 7970 plug in but when i plug the 980 ti in the pc dosnt want to start. there is no beeps just refusing to start even when the 980 ti is not in the board it boots
wat i mean about the 00 missing is the some of the resister has broken off
MadDog さんによる
is there any way of bypassing that resister to see if it has damage any other part of the gpu?
MadDog さんによる
the psu i am using is a 650w gold from evga
MadDog さんによる
