メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Gas leaking from engine?
Hey everyone. I had been smelling gas coming from my 2005 cavalier. I just pulled out of my parking spot and noticed a sizable amount of gas on the ground. I haven't popped the hood yet it's 9 degrees here but just wanted some input. Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@westhavensean,Sean, It will probably be a rusted out/damaged fuel line or connection. You really should discontinue/restrict your driving until repaired as it could be a fire hazard waiting to happen if you do not wish to address the repair yourself. Have a reputable shop have a look and estimate repair.Good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I'm having the same problem with my 2005 Cavalier gas in the air box I had a crack in the side of my fuel pressure regulator line thought maybe that was the problem fixed it still doing it fixed another vacuum line thought it might help but it didn't so me too and trying to figure out where the hell all this gas coming from
さんによる
コメントを追加
回答を追加する
Sean Rasmussen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 781
