This should not be marked as answered. It is not answered and it is not a lamp failure issue. I had it before and held down some buttons and it worked but I cannot for the life of me find where I got that information from. Benq are currently useless. If I manage to find out again I will come back and answer it properly.
Ok …
1) Disconnect all cables plugged into the projector and press the ON button for 10 seconds; (All cables unplugged).
2) After step 1, please wait 1 hour before attempting to restart;
3) Connect only the power cable, and check if the initial BenQ Logo image appears.
4) Connect all other cables.
So all cables out and hold down power for 10 seconds. I didn't wait an hour and just plugged power back in straight away. Worked. Then connect all other cables.
You have 100% got this!!!! Just keep on keeping on!
14 件のコメント
Has anyone solved this?
Lachlan Milford さんによる
Benq ms504p projector showing lamp red light,lamp not working
Rohit mutha さんによる
i have to this issue can you tell me about red light problem i am change lamp but still its same
Naseer さんによる
Yeah, the "Download" description isn't very helpful. I did a word search, and the only other time the word download is used in the manual is on Page 44 with the Baud Rate of the Advanced Setup Menu. Here it is talking about downloading firmware, so most likely the "Download" description you found is referring to downloading firmware as well. Unfortunately, Page 44 also says "This function is intended for a qualified service technician", and I was unable to find anything on firmware updates for your model.
Tim D さんによる
Thank you for your answer.
Let's talk to a service technican.
Stig Pfau さんによる
9件以上のコメントを表示
