メインコンテンツにスキップ
Samsung Galaxy S6 Edge+ はGalaxy S6 Edgeスマートフォンの大型モデルです。
99回答 すべてを表示
Display has something printed beneath it
My Galaxy S6 edge plus screen is showing a kind of screen shot stuck on it, it's a big download button with "downloading" written below it which is very light intensity but the download button is right in center and it's intensity is a little high. Also very closely I can a notification bar in the top half of my screen. It's showing on every screen.
Touch is working fine though and not a UI issue as I have tried factory reset and screenshot multiple times and nothing is visible when I see the screenshot on another device.
Help me out please.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Samsung display are very nice but they are also known for having screen burn in(SBI) issues or ghosting. This is especially true at the top of the screen where the status/notification bar is located. If an image sits for an extended period of time without any movement(such as the status bar) that image can be burn into the screen and be seen faintly no matter if your on the home page or using an app. They do make apps that are basically screen savers to help prevent SBI. I have also seen apps that claim to help fix screen burn in issues. I do not know if they work or not but it could be worth a shot. Just search the Google play store for screen burn in if you wish to try that. It is simply a cosmetic issue as you me already know, but just in case you did not, do not worry as it does not affect the functionality of the phone, just its appearance.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you so much for answering. I will give it a shot and see what happens. I know functionality of the phone is fine but that burn is bothering me specially when reading documents on the phone so need a proper fix for it and exact name for this problem.I will try your solution! Thanks
さんによる
コメントを追加
I am facing the same issue on my S6 Edge plus? Any update on Fix?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Laksh Mandhan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 503
