メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年10月26日にリリースされた第4世代のSurface Proタブレット。
Blurry texts and screen flickers
Texts are blurry, screen flickers and video/image moves under frozen one.
How to correct it ?
Image and text on the screen use to tremble, up and down, from time to time. When this happens image and text become blurry.
When video is playing,sometimes, one frame freezes, while in the background the video is still playing.
Is it a software related problem or a hardware malfunction ?
(once I hooked the Surface to a monitor, the video played fine,while the problem persisted on the Surface screen)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
11 件のコメント
Hi,
If it was software it should also affect the external monitor.
It could be a video cable or a tablet screen problem.
How long have you had the tablet?
さんによる
I have the same problem with my Surface pro 4, which I have had only for about 18 months, the problem started several months ago, and is getting worse. It makes it very hard to do projects! I have searched the Internet to see if there is a way to fix this problem. I love the Surface Pro 4, but unless Microsoft comes up with a solution, I would not buy another of their products like this! Microsoft needs to fix this, as many are experiencing the same issue!1
さんによる
My surface screen is going blurry, looking like multiple docs are open on top of each other. Can’t read any of it. Screen becomes unresponsive. Does anyone have any advice? Thanks
さんによる
I am experiencing the same thing on my surface pro!
さんによる
I just started having this problem. My surface pro 4 is about 17 months old. Happens when the device gets hot.
さんによる
6件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Call Microsoft, this is a known issue covered by extended warranty.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
This worked for me. https://www.groovypost.com/howto/fix-fuz...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Emilcar Similien さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 26
今までの合計 17,362
