メインコンテンツにスキップ
Nintendo Switchは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
708回答 すべてを表示
How to charge a Nintendo Switch in the car!
Ok I got a brilliant question for our techy community out there... The Nintendo Switch says on the back of it that the input is 15volts. On the power adapter it says it outputs 2 different voltages one output of 5 Volts @ 1.5 A and a second of 15 Volts @ 2.6 A.
Now as I read it takes the 15 volts to actually charge the system and 5 Volts for something else. Then I read no 5 volts is the charging rate and 15 volts to like use it with the dock...
Now any idiot would know that if you put 15 volts into a 5 volt charger is going to blow it up and if you put 5 volts into the 15 volt port its simply not going to work, and would actually probably be more damaging to the unit rather than just putting in the voltage it calls for.
Then I see the car chargers are going to have 5 volts, so how is that suppose to charge a 15 volt system?? its like what the heck is going on is this system 5 volts or 15 volts??? Why is this so %#*@ confusing????
Now a normal USB-C connector would only seem to have 5 volts going through it not 15 volts... So someone help me make sense of this beast is it powered by 5 volts or 15 volts, and if its 5 volts then why does it say input of 15 volts??
PLEASE HELP
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
What I think it is is that the switch system it's self takes only 5 but the switch dock runs the hdmi output and 3 usb ports so the 15 has to suppily power to all that in dock mode. In portable mode it has a regulator chip that keeps it at 5 for portable mode in both the charger and switch system.
さんによる
I guess this is a good place to share my favorite solution:
http://amzn.to/2E3rzRZ
It can fast-charge both my Switch and my S8 at the same time!
さんによる
https://www.verizonwireless.com/products...
That charger had correct voltage and amp and works very well. Came with my s8 and was happy to find it works great for the Switch.
さんによる
コメントを追加
9件の回答
ベストアンサー
I am not sure what each voltage is for but I do know that Nintendo have made a branded and licensed Nintendo Switch car charger. I'd recommend getting one of those or at least finding out the specs for it.
Hopefully that helps.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
Well i finally found the car charger for it and yes you were corect they do make a car charger for it... Gamestop and Walmart and Target dont have this item yet the only place Ive found to have it is Best Buys. Plus Id caution using sites like Amazon to shop for these people are price gouging the heck outta there $19.99 items for nearly double there costs!! So buyers beware!!
さんによる
That charger is great for the Switch in the car also.
さんによる
the car charger is not for the dock mode
さんによる
コメントを追加
最も参考になった回答
USB-C by default runs on 5V, like every other version of USB. This allows you to plug a USB-C charger into any device, without blowing it up.
The Nintendo Switch however supports USB-C Power Delivery specification at 15V.
When you plug it into the AC adapter the Switch pulls 5V but then asks the PSU "Do you support USB PD? I'd really like 15V 2.6A please.". The PSU then responds saying "Here you go." and switches to 15V.
The Nintendo Switch only needs 15V when in docked mode as it uses twice as much power, its perfectly happy on 5V 2.4A playing BotW in portable mode, it still charges. It most likely charges quicker with a USB-C PD adapter though.
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
It doesn't use 15v at all because the battery is 3.7v, but 15v is a required specification for usb-c power delivery even if the device being used does not require 15v. My samsung chromebook plus's battery charges at 15v and the battery holds 7.6v. 5v and 15v are both required specs for usb-c pd, but samsung has 5v 9v and 15v on their usb-c chargers
さんによる
コメントを追加
Regarding USB-C connectors, those are not rated for any particular voltage as they do also charge things like the Macbook/Macbook Pro, A lot of other Windows Laptops, The Chromebook Pixel, Cell Phones... and all of these are rated at different outputs.
My best guess is that the system can be charged at 5V, but charges faster (and probably while playing it) at 15V. Kind of like you can charge an iphone with their 1 amp iphone charger but it also charges faster with the ipads 2.1 amp charger.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Im guessing the 15V is for the Nintendo Dock which allows you to play-n-charge at the same time so thats probably why it can supply the 5V and 15 Volts. As it would take a lot of voltage to play-n-charge at the same time. And my guess it that playing it while charging in the really don't charge it that much as it has to operate (play) as well as charge.
Plus yeah there is a Nintendo Car charger for it but it only supplies 5V at 3 Amps. So it definitely takes a lot to charge it!!
さんによる
コメントを追加
Folks. You are close to getting all the pieces of the puzzle. So let me explain.
You need a USB Power Delivery car charger. But there are a couple of different power profiles supported by the USB PD standard. So you need to have a charger which supports the higher power output profiles to be able to charge while playing. That's what we all want to do on those long trips right :). So 15 volts/2 amperes (30W) would not be sufficient if you play some of the power hungry games (i.e. The Legend of Zelda: Breath of the Wild).
So I would strongly recommend you using 45W+ power profiles.
Here is a charger I found, just recently released:
http://amzn.to/2kqKzkC
You wont find many car chargers which give you more than 36W USB PD output (12V/3A profile) out there. The reason is that all the big brands are putting their bet on Qualcomm Quick Charge standards which is not compatible with USB PD hence doesn't work on the Switch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'm guessing but... Isn't it possible that the power adapter has 2 different outputs (5/15), because it's so intelligent that it choose what voltage instead you are recharging only the Switch or the Switch and 2 joy-cons?
Maybe it's absurd but think about it... Switch can be recharged with any type of usb C, not necessarly his power adapter. But what happened if I decide to recharge Switch and the 2 joy-cons with only 5 volt? Probably it works but first it recharge the Switch and then 1 joy-con at time.
What do you think?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Well yes and no, yes 5 volts can charge it BUT the trick is you need a device that can dish out 3 amps of charging juice also!! Not many chargers these days can support a 3 amp charge, most of them are 5V at 2.4 Amps max.
If you don't give it the minimum 3 amps it needs it could harm both the Nintendo Switch and the charger your trying to use!! More than likely if you used a 2.4 Amp charger it would be liable to burn up the charger!!
さんによる
If the charger is REALLY designed to handle 5V 2.4A then there is no risk of it burning out doing so, the Switch can only draw what it supplies.
The risk is that many cheap PSUs lie about their capabilities and/or are completely out of specification. Stick to a good brand like Anker though and you should be fine.
さんによる
コメントを追加
I don't mean to be rude, but I'm kind of surprised that nobody has said that the switch only takes 5 volts and 2.4 amps to charge while playing (though you can use less amperage if your not playing it) but the 15 volts is only to power the three USB ports on the dock. So In all reality. Any car charger will work as long as you have the USB type c cable. However if you do want to find a charger that will charge while playing, Nintendo probably has the best solution since most car ports are only 1-2.1 amps, so you'll actually lose battery while playing intensive games like botw
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not really true. USB don't take much power to run, and currently it doesn't even support hard drives. The 15V is because it would take forever to charge at 5V. Will it charge? Yes. Even while playing Zelda? Yes, very slowly. But the official charger with PD can charge super fast while playing Zelda, and that's why you should want PD. Not for USB devices.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
USB supports drives, and the voltage doesn't determine charging speed, that is measure in amperes. Only reason 15v is a spec is because it is required for it to be classified as usbc pd
さんによる
@Evan Elm The reason they chose 15v is because its hard (and against USB specification) to push more than 2.4A through at 5v without needing huge conductors to avoid losses. That 15v will be stepped down in the Switch and/or Dock to 5v where the track lengths are short and its easy to run extra tracks to different components.
The people reverse engineering the dock even suggested that the Switch uses a variation of USB-PD that doesn't meet the official specification.
さんによる
A lot of usb-c chargers don't meet requirements. Like my samsung chromebook plus charger, requirements don't say 9v 3A, my samsung charger pushes out 15V at 2A, and 9 or 5V at 3A. Image at: https://i.ebayimg.com/images/g/ceYAAOSwb...
さんによる
コメントを追加
In a vehicle, you would tend to not need the compactness of one small cigarette lighter adapter that can reliably power the Switch using USB-C Power Delivery at 18 watts.
If you think outside the box a little, you can add a good quality power inverter, such as amazon.com/dp/B00153BH6M or amazon.com/dp/B001539B7O
and then use the AC adapter that came with the Switch, or a good quality AC adapter known to be PD-compatible with the Switch, like amazon.com/gp/product/B01LX063QN
You are also giving yourself the flexibility of an AC plug and not just a USB-C, so you can use it for other things as well. However, please understand that an inverter that plugs into the 12V "Cigarette" port can not pull enough current to power most power tools or anything that heats like a coffee maker, curling iron, hair dryer... And you can plug a power strip into the inverter's outlet to plug in more things at a time, just try to keep it under 175 Watts or you will blow the cigarette lighter fuse in your car.
Efficiency is an argument, certainly, if you're living on solar cells and batteries you would not want to invert 12V up to 120V just to drop it back down again with a USB-C AC adapter :-) ... I'm just trying to help people looking for solving the problem of taking road trips with their Laptop/Nintendo Switch/other electronics. Without going into a lot of technical detail, the GoPower brand ones I linked are very good, but a "Pure Sine Wave" inverter would be best, however the price goes WAY up ($148) and for the Switch a pure sine wave really isn't needed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Tried using the Nintendo charger. Works fine on the lcd unit but not on the docking station. Even tried an inverter on the docking station in the attempt to play on our 17" drop down tv. Sadly, can only get the docking station to work on the house mains. bummer.
anyone got any ideas how to charge the whole unit in the car? ps, 12v power supply only has a 15amp fuse
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Is this is the proper Nintendo Switch charger that you normally use on the house mains?
If that is not working with an inverter then you probably need a better inverter. There is no reason it wouldn't work with a proper sine wave inverter as the output should be indistinguishable from mains, but many cheap ones only output square wave which can be a problem.
As for using anything other than the official Switch mains adapter, I do not believe its possible as the Switch doesn't use standard USB-C power delivery,, as was discovered by people trying to reverse engineer the dock.
さんによる
I have posted the solution I found upper in this threat but here it is again:
Enjoy.
さんによる
Best solution (I live on 12V and Solar)
1. Buy a DC-DC Voltage Boost Module listed below.
https://www.ebay.co.uk/itm/DC-DC-LTC1871...
2. Wire it directly to your 12v battery with a fuse rated at the amps the Nintendo will draw.
3. Attach a volt meter to the output side. Twist the screw until you get 15v.
4. Cut the end of a USB C, AC adapter. Wire it directly into the DC-DC Booster.
5. Plug and play!
BE AWARE. WHEN YOU TURN THE ENGINE ON YOU MAY GET VOLTAGE FLUCTUATIONS THE DC-DC BOOSTER DOES NOT FILTER OUT. BEST TO PUT A 12V CAPACITOR BETWEEN THE ENGINE BATTERY AND THE DC-DC BOOSTER.
Also if the engine is not on you will be draining the battery like leaving your lights on so watch out.
Also this same system can be used to charge a Mac Book, or any device running on DC as long as its in the range of the DC-DC adapter.
さんによる
hey bro(lewis martin) .. i need some help on the same lines .. could you please give me your email .. please help me
Regards
Rahul
さんによる
@martinsmayhem :
Regards
Rahul
just now by rahul9nb
さんによる
コメントを追加
回答を追加する
Matthew196 さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 76
過去 30 日: 278
今までの合計 90,907
