Why is my headset only working on one side?
My headset only works on the right side. But it works on the left side when I push the cord up where it connects to the jack. I would be grateful for any help.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It sound like the cable is broken.
Have you tried it in another device to make sure it's not the audio port?
You can attempt to fix it by replacing the cable, which will likely involve taking the headset apart, finding where they cable connects to a circuit board, de-soldering and re-soldering a new cable.
このアンサーは役に立ちましたか?
Thank u so much. I did try it on 3 other devices
ive tried the cable on other devices and am certain that it works, if this is the case what can i do?
過去 24時間: 1
過去 7 日: 15
過去 30 日: 61
今までの合計 33,481
1件のコメント
Is there another way to check the not working part? Even with changing the cable, only one (the same) is working. In my case it's a Sennheiser HD 430.
(Yes very old. But I liked too much the natural and transparent sound. What would be a good replacement?)
TIA
Jochen Buthe さんによる
