メインコンテンツにスキップ
2014年10月16日に発売された iPad Air 2は初代 iPad Airの継続版でより薄くなったスタイルです。
450回答 すべてを表示
iPad will not recharge.
The Battery logo light shows up , but will not charge. Battery is so low it will not reboot by pushing Home and Power buttons. I have tried various other chargers and cables that are working on other iPads.
It seemed to be charged and working fine but then went black and will not charge and/or start.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
first thing id try is cleaing out the the 30pin connector dock, and try charging again, if that doesn't work, replacing the dock would be the next option, then battery...
さんによる
Thanks for your answer. Comment below.
さんによる
The iPad Air series uses the 5-pin lightning connector not the 30-pin connector for the charging port.
I wonder if it's just a loose battery connection.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Sounds like the battery needs to be replaced. How old is the iPad? If it's under a year and you have no physical dents on it then you might be able to leave it under warranty to Apple. If it's over a year then try to leave it to a workshop that can give you a price quote before repair.
Also, you could leave it with apple if it's over a year old too and ask for a replacement unit but that might be a bit pricy.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for your answers. I tend to agree with the Battery replacement scenario. I bought it new last June so it ought to be under warranty. Although I did buy it with my United miles. I hope Apple covers that. I don't see why not unless they use that as a loophole.
Anyway , there's no dirt or lint in the connecter. Off to the Apple store. If that doesn't work then onto iFixit.
さんによる
コメントを追加
回答を追加する
bbmack さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 176
