メインコンテンツにスキップ
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
20回答 すべてを表示
What dose f:01 mean
when the washer start it stop and f:01 comes up
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
Any updates?
さんによる
start as the machine starts counting down lid locks and f001 comes up
さんによる
コメントを追加
3件の回答
It is an error code for a bad control board
Look at this link for tips to repair it: http://www.f1error.info/repair_whirlpool...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Posts on here refered me to an air hose near the control board. Check for it being crimped, you can blow through it and make sure you hear air coming into the drum. This can be your issue not your board, people have bought boards and still had this problem. So check the hose first. F1 is referring to pressure not being right on the water from air flowing against a sensor via this tube.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
As previously mentioned, F.01 can either be:
1) control board and/or
2) air tube that plugs into control board
You need to check the tube is clear, not kinked or if your control board works.
You should run the diagnostic on your make/model which will cycle through all the water intake steps C0 through C7 which will test the function of said tube as well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
RoSkittles :o さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 3,641
