My tablet won't charge
why won't my tablet charge
この質問は役に立ちましたか?
@shiningstar15, Carly , A lot of forums feel a factory reset can fix this type of issue, read and follow the steps in the first link below if you would like to try, all data not backed up will be lost.
Reset did not work, either the cable or charge port may be damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, it is probably a damaged/loose port that will have to be repaired/replaced. If port looks/test good the battery or connection is probably bad.
If port is found to be bad, this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board (not your exact device). If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Another option would be to do a search for a good replacement complete motherboard which as an assembly would be fairly easy to change(last link MB less then $15.00). Good luck.
http://unlockandreset.com/rca-tablets-al...
RCA RCT6773W22 Motherboard Replacement
このアンサーは役に立ちましたか?
try factory reset if that doesn’t work then take it to professionals they know what to do
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 44
今までの合計 5,908
