メインコンテンツにスキップ
Dust getting inside of the screen.
Does anyone else seem to have this problem? It seems like there are specs of dust that are getting inside of the screen. Anytime there is a white background you can tell that he screen is ridiculously dirty. I was wondering if it's possible to take the screen apart somehow and clean it. I have found no guides that explain how to take apart the anti-glare screen once its removed from the CPU.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Very risky procedure!
Unless you have access to a clean room you'll end up with as much, if not more, dust inside as before you started, and there's a good chance you'll damage the LCD in process of disassembly/reassembly.
Good Luck,
N.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I agree, it's a very risky procedure.
I had a big flake of dust inside my 13" MacBook screen, that was driving me nuts. As it is an older model, and I have things set up so I can pop the same drive and boot my Hackintosh (as a backup), I thought I'd go for the surgery.
It's not for the faint hearted.
I disassembled things down to the "LCD Replacement" level, and got the LCD unit separated from the MacBook. (This alone isn't for the uninitiated.)
Examining it with a flashlight, the problem was indeed inside the LCD unit.
Feeling gutsy, I disassembled the LCD unit itself. Required careful removal of tape (including some metallic tape that no doubt served grounding purposes), and unhooking some catches around the edge of the metal bezel.
Then I was able to lift the LCD glass, and see two clear matte sheets whose job was to diffuse the backlight. Under the second one, I found and dispersed the big fleck of dust.
It took quite awhile, with bright lights in all directions, a HEPA air filter on high, and a lot of patience, to ensure I wasn't adding *more* dust inside the unit. In the blink of an eye (literally) an eyelash can land in there, making things worse than before. And you really should use those gloves that photographic folks use, to avoid adding any smudges inside the LCD. (I added a couple of smudges, and they were incredibly difficult to remove properly.)
Also, you want to ensure your work surface is clean, and has something soft on it. Removing dust is no good if you add some scratches to your screen.
Eventually I was satisfied that everything was clean and better than before, and reassembled. (A fairly long process, getting the LCD back together, re-running all the wires for the Mic, iSight, etc., around the sides properly, and getting the screen re-attached.)
Most intensive repair I've ever (successfully) undertaken. I'd only recommend it if you know what you're doing, have a relatively dust-free environment, and/or you're willing to potentially sacrifice your screen (and require a replacement).
It worked for me, and I'm very happy with the results. But I would never recommend anyone undertake this. :)
-DG
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sound answer + Ralph
さんによる
コメントを追加
I have the same thing with my MacBook Pro 15" old style. If I get a new laptop then I will try and do this and put a post of how I do.
Steve
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Manny さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 10,212
