メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Backlight turns on but not the LCD
I recently had my screen replaced and a few days later, the lcd froze and looked like it was fading black from top to bottom going towards the middle. I've never seen this before. I've tried restarting the phone, checked the connections and tried a new screen on it and all its giving me is that the back light works but the lcd isn't. Can anyone help me with this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hi Ben, did you end up fixing the phone? I am currently having the same issue with my iPhone 6 Plus and am wondering if you have resolved your problem. Please comment what you did to fix it, that is if you fixed it. Thanks
さんによる
コメントを追加
2件の回答
ベストアンサー
Sounds like a faulty display to me. Bring it back to/request a replacement from where you got it
このアンサーは役に立ちましたか?
スコア 3
17 件のコメント:
I've tried different displays and they only give me the backlight
さんによる
Really. Inspect the LCD socket, check for damage. After that I would guess it's an issue with the gpu
さんによる
I have spare screens right here. I just tried a new screen and now the new one doesn't turn on but when I plug it into itunes its recognized. But when I put back the old one the backlight turns on.
さんによる
I'm full of sleep medicine. So I'm confused. What do you mean the old one works, but the new one doesn't?
さんによる
So how do you know which Ben is Ben?
さんによる
12件以上のコメントを表示
コメントを追加
As long as you're getting full backlight but no image check chestnut ic. This provide voltages to touch and display. It is most likely not gpu related. I would still inspect coil for cracks/damage as it might not be putting enough voltage through to give full backlight to image.
If you tilt the board and look under chestnut (u1501) you might be able to see under ic for cracked solder balls. I normally don't recommend reflowing but you could put some flux on the ic and heat for about 20 seconds at 355 if balls underneath look cracked.
Also check voltages out from u1501.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ben さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 6,642
