rubber burning smell from unit and now doesnt work
unit doesnt work something seems to have burnt out
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Kevin Currivan, If under warranty, return for repair/replacement/refund. If not under warranty use the link below to dismantle the device and check the cord/parts for burns/wear/damage. If the cord is burnt off, cut off the bad section, strip insulation enough to reattach with similar wire nuts. If it is a different part that is damaged you can do a search for Magic Bullet NutriBullet replacement parts. Good luck.
Magic Bullet NutriBullet Activator Replacement
If your NutriBullet blender will not turn on, use the Magic Bullet NutriBullet Won’t Turn On problem page for possible problems and solutions.
このアンサーは役に立ちましたか?
Well, if you are familiar with repairing electric appliances, this is great. For me, not so much. I wish you were my neighbor, LOL
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 12,302
