メインコンテンツにスキップ
2014年10月16に発表されました。モデル番号はA1347でEMC番号は2840です。
197回答 すべてを表示
Where can I get the torx T5 and T6 screws I need!?
According to the teardown I need the following screws (having retrofitted a PCIe blade into my Mac mini and set it up as a fusion drive).
Need - 5 mm T5 screw to secure the end of the SSD
Need - two 2.6 mm T6 screws to secure the PCIe SSD cable bracket
Its all currently working fine, but I'm missing the screws and its all being held together with a sliver of duct tape! Also does anyone know where to get the actual bracket itself that holds the ssd cable onto the motherboard? It didn't come with the cable kit I purchased, and whilst it is working OK, I would like all of this for piece of mind if possible. Surely the screws can't be too hard to obtain? Can they!?
Many thanks,
Richard
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
@r1chowen , Rich, Pop into a local cell/computer repair shop and take your screws to match up or your vernier to measure them, repair shop should have spares kicking around to purchase or give away. By chance if it is a repair center that works on Mac's they may have a used bracket also. Good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@r1chowen, Rich, I had checked ifixit 1st and saw they were out of stock can you not just pop into a repair shop to match them up, they have verniers to measure for correct size.
さんによる
コメントを追加
@r1chowen buy a proper screw set for your Mac Mini from here. That way you know that you have the right screws and do not cause any damage by using wrong screws.
Mac mini A1347 (Late 2014) Screw Setの画像
製品
$14.99
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks. Do these kits contain all the screws in a Mac mini or only a selection of the most common? If the former that's ideal! Not in stock though :-(
さんによる
コメントを追加
回答を追加する
Rich Owen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 11
今までの合計 2,973
