Squeaking sound on take off.
On take off I have revolving sqeak under car for about 25-50ft.
Kent Gillespie, Probably a bad U joint, other possibilities brake caliper not releasing, ebrake/wheel cylinder sticking, bad wheel bearing,worn bearing in rear end, suspension bushing dry, fan/pwr steering belt, etc.etc..I have even had tire with low air pressure squeak. Have a good mechanic take it for a test drive to confirm or diagnose. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 9
今までの合計 117
