メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
Charging problem after battery replacement
Replaced the battery on my iPad 3 today due to the old battery not charging. The problem I am having is after I replaced the battery the iPad now continuously connects and disconnects while plugged in. I have triple checked all of the connections and everything is plugged in properly and all connections are clean. Any idea as to why this is happening?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
When you say you have triple checked the connections, have you checked to make sure the contacts on the battery are making a good connection to the motherboard? Did you test the charging and functionality before closing the iPad back up?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I initially thought that might have been the issue so I put a small shim under the battery contacts. That did not solve the issue. I closed the iPad back up, but it's easy to tear down again if I need to because the adhesive needs replaced.
さんによる
コメントを追加
Sounds like it might not have been the battery that was the culprit in the first place. Do you have a new charging port to try? Worst case scenario it might be an IC issue, more specifically the U2 IC might be fried.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I don't have a new charging port, but I can easily get one. I'll replace it and update.
さんによる
コメントを追加
回答を追加する
jeninholland02 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 29
今までの合計 290
