メインコンテンツにスキップ
2015 Retina MacBookの最新モデルです。モデル番号はModel A1534, EMC 2991です。
Little yellow button on logic board - what is it?
MacBook Retina 12" Early 2016
My MacBook doesn‘t turn on after SMC reset. I've found on Apple pages that this can happen if you reset the SMC without your MacBook connected to its AC power adapter. I've also tried PRAM and SMC reset and nothing.
Black screen, no charging sound and battery picture when connecting to power supply.
I wonder what is this little yellow button on logic board for? Do any of you have a problem like me?
Does anybody know location of power on pads?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
1件のコメント
Pressing this button brought my MacBook back to life. It had died during attempted update to Catalina 10.15.6 and was completely unresponsive. After pressing the button 3 times 10 seconds each, and then powering up, the install completed successfully and the computer works fine.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Old Post, but commenting for prosperity.
EXTREMELY IMPORTANT
For this model MacBook it is IMPERATIVE that the battery disconnect button be held for 10s (until the tiny led dies) before removing the track pad flex, else you can kill the logic board.
On power back up post repair it is IMPERATIVE that the MacBook be connected to a standard USB charger (5v 0.5-1a) until it powers on before connecting to the standard MacBook charger. This is to wake up the power management circuit. Connecting directly to a standard charger after having disconnected the battery can likewise permanently damage the logic board.
このアンサーは役に立ちましたか?
スコア 8
1件のコメント:
You are a life saver! First time working on this model and I was very confused. Don't see them too often these days lol
さんによる
コメントを追加
As far as I can work out, it de-energises the battery rails.
I'm also looking for the power on pads. and can't find them. They're listed in the servicer manual though, so should be somewhere...
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Correct, always press this button (hold if 2016 onwards model) and wait for the light next to the battery to go out before disconnecting the trackpad cable, otherwise you can kill the MacBook (trackpad deals with G3H always on rails).
If it is dead after an SMC reset, take it to Apple and they should sort it if it isn't too old. If they are not helping, press this button on the logic board, then plug the charger in. If it is still not working, there is an issue with the logic board most likely.
さんによる
Also, you don't need to use the power pads. When this is de-energised, it will boot up by itself after the charger is plugged in
さんによる
Have you solved the problem?
さんによる
So, removing the trackpad cable will kill the mac, if I don't press that button first? This is nowhere in the disassembly guides. ARGH! Is there a fix? You mention taking it to Apple?
さんによる
How i can energise the battery rails again? i have pressed this button and macbook doesn't power on.
さんによる
コメントを追加
I did the same thing: I initiated a restart, then held down the “shift, control, option” keys and hit the power button without plugging it into . My MacBook never started back up, same as the above post.
I followed the plan that the original post: opened the computer and pressed the small button adjacent to the internal lcd power light with the computer plugged in to the wall outlet. The charging alert rang and I knew my computer was back to life.
Do follow the disassembly instructions on ifixit when you are removing the screws and removing the bottom casing. The flex cables are very delicate.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Wojciech Pawlowski さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 22
過去 30 日: 112
今までの合計 12,028
