Makes beeps when the pc turns on and pc dispaly doesnt sho
When my pc turns on it constalty makes beeping sounds and doesnt stop the diaplay doesnt turn on,the monitor works fine
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The 5 beeps is a memory or motherboard problem. I would remove all but one of the memory modules and test each one individually and find the one that may be bad.If the PC beeps 5 times with all of the single memory modules tested at a time, then the motherboard is shot. Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 30
今までの合計 1,054
3 件のコメント
joseph 5052 are you saying it beeps continuously? As soon as you turn it on?
oldturkey03 さんによる
Hi,
Is there a pattern to the beeps?
Count them and see if there is a pause and then it repeats the sequence over and over.
It can be up to 9 beeps in a row or even a code such as 1 beep 1 beep 4 beeps 1 beep 1 beep 4 beeps or something like that.
Listen for the pause between the beep pattern. It is slightly longer than the time between the actual beeps
jayeff さんによる
it happens when i turn it on it makes 5 beeps and a pause and keeps going and does'nt stop.
joseph 5052 さんによる
