How do I get the power button working on the leap pad ultra?
My sons leap pad the on and off button will not work , where can I get it fixed .?
Annalise Martin, Find below a tear down guide link, that could aid you getting inside the device to clean the button and connections to possibly get it working again. Replacement button may be hard to find. Remove/clean around the button and connections with a Q-tip/small brush dampened with 90% Isopropyl Alcohol to remove all grime/dust/corrosion, then try device. If not wanting to try repair, you can contact leapfrog support at the last link below for repair facility or take it into a local computer repair shop have them take a look, diagnose and estimate repair. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 14
今までの合計 1,560
