メインコンテンツにスキップ
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
Solution to unresponsive volume buttons?
ZTE ZMax Z970. The volume buttons are randomly responsive, will work for an hour or two before I have to go back to adjusting my volume through settings. I'm not sure if this is a hardware issue or software. Possibly related: adjusting the headphones jack when something is plugged into the phone causes the Google app to open up and listen for commands; sometimes, it will suddenly increase the volume in increments and I have to manually change it back. Where would I take it to be repaired?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
You should download the app called
Virtual volume button that should fix the problem
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Okay so I'm not exactly an expert but press the center of the volume buttons into the phone and that fixed mine actually a little bit to where they are more responsive. If that doesn't work then play with the buttons to find an angle they work at.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Cassandra Pentaghast さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 7,472
