メインコンテンツにスキップ
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120回答 すべてを表示
Intermittent charge Galaxy Tab 3
My Galaxy Tab 3 takes days, sometimes a week to charge while turned off using any charger,. Turned on, it goes in and out of charge mode and never fully charges, in fact, it actually loses charge probably because the screen and charge tone are constantly going on and off. It`s even worse using the OEM charger.
I have recently replaced the battery with an OEM part with no change.
Any help you people can provide will make you my heros and sheros forever.
Thank you
Bart
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
try going into settings and turn on power saver mode. Then turn it off and put it on the charger.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I turned on power saver, then powered down the device. OMG! It only took a few hours to charge! Thanks tecfix4u! ...whoever you are!
さんによる
コメントを追加
Re: OEM charger, did you use a new cable AND plug adapter? Cables can go bad as well.
Possible the charging port may be bad or damaged as well. Inspect it with a magnifying glass for any bad soldering, broken off jumpers, and broken pin(s). Have you replaced the charging port itself? Some tab 3 models have a port that is attached to the logic board by a (16?) pin connector. If you have one of those then replacement is EASY, otherwise you'll need expert microsoldering skills to swap out the charging port.
I'm assuming OS is up to date. Good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Appliance Connectors さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 126
