メインコンテンツにスキップ
Appleコンピューターにワイヤレスで接続します。
How to repair unresponsive "Enter" key?
On my Apple wireless keyboard, the "Enter/Return" button randomly stopped working. Is there any way to repair the key?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
Need help too! Can't type because the return/enter key won't work. Please help
さんによる
Did you try cleaning the pads as I explained? The newer versions of the keyboard are now sealed so you'll need to replace it (not repairable)
さんによる
My return/enter stops working and while I was searching find a not perfect but good enough solution. At least I can use it till I will buy a new keyboard. So there is a software karabiner https://pqrs.org/osx/karabiner/ at the link and you can change any key to any key (Remap) by using it. So I replace eject key (which I never use) to enter key. It is working with the latest OS Mojave.
you can change any of your keys to any key for example you can change right shift to return key either.
さんによる
@ubeyds that worked for me! Thanks for taking the time to help :)
さんによる
コメントを追加
3件の回答
ベストアンサー
I would see if a cotton swab that is just moist (not dripping wet) with 85% isopropyl alcohol can clean the crud around the key as it just could be getting stuck. You may need to go a bit deeper here by carefully lift the keycap to get under the key to do additional cleaning as gunk could be effecting the scissor mechanism as well underneath.
If that doesn't fix it see if the batteries leaked as the chemicals in the batteries could have damaged the conductive traces.
Sadly, these keyboard are not very serviceable. Here is the IFIXIT teardown: Apple Wireless Keyboard (A1255) Teardown. Jump down to Step15 to see how to pop the keycap.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Is there any way I can make the "return" key act as an "enter" key so i don't have to keep using the mouse to press enter? Or do I have to download something ??
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
ur a moron, u have reached maximum stupidity
さんによる
コメントを追加
You can only do that by replacing all the keyboard keys, where you need to be well experienced to perform the operation since there is head involved and if not well done you end up frying the chassis. The best option will be to replace with a new keyboard. If this is helpful, do not forget to mark.Tx
このアンサーは役に立ちましたか?
スコア -2
1件のコメント:
I don't think you need to go that far ;-}
さんによる
コメントを追加
回答を追加する
marc さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 29
過去 30 日: 155
今までの合計 85,937
