メインコンテンツにスキップ
An in-car GPS manufactured in 2012 by Garmin.
10回答 すべてを表示
Charging port no longer charges
I have replaced the battery on my 3590.
The new battery (tried two different ones) was fully charged before connecting it.
However, whether I plug it into:
1) The wall charger
2) Laptop USB
3) Cradle charger
The battery will not charge.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Colin Marson , I take it worked on the new battery till it died and now refuses to charge. Did you check the port and blow any dust/debri out of port. Look in port and straighten any bent pins with tooth pick very carefully. Still no go, remove battery door and with a DVOM with charger plugged into device check plug at battery to see if charger is sending voltage to battery, if not probable loose/bad charge port,change the charge port. the link below is a tear down guide that can get you access to the charge port which is soldered to the mother board and is not a job for the newby because of the fine components and heat involved. 2nd link shows a charge port being resoldered.Good luck.
Garmin nüvi 3590 LMT Circuit Board Replacement
https://www.youtube.com/watch?v=5z5KLwKn...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The difficulty is that neither the USB port nor the cradle connection seem to be providing a charge ( the battery icon does not show that it is being charged)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Colin Marson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 8
今までの合計 2,050
