Where is the temperature sending unit on a 2006 lacrosse cxl
Temperature gauge quit working on 2006 Buick Lacrosse CXL. How can I tell where the problem is?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Coolant sender unites do fail from time to time but before taking it out make sure you have enough coolant in the system for the sender to work . Often people will think there car has fixed itself when its running hot and then the temperature gauge goes down to nothing . this just means theres no fluid in the system at the sender . without the fluid there the sender cannot send a temp so it goes to zero. So before replacing the sender make sure your fluid level is up to proper levels. Hope this helps
このアンサーは役に立ちましたか?
If the coolant had gone low, this would allow air into the system and on the Buick 3.8 will have to be bled out/burped or the air pocket could cause this issue. Just refilling the coolant is not enough sometimes.
excellent point @lpfaff1 Just this week I was 3 hours bleeding the air out of a 2001 Honda civic that wasn't giving any heat . I ended up raising the rear of the car to finally get the air to move enough to get heat in the car. Very frustrating
@jimfixer , Jim sometimes that is the only way that seams to work, it can be a bear even with suction or pressure systems.
abbyshepard10 the cause could be a bad Engine Coolant Temperature (ECT) sensor.
3.6 L engine
3.8L engine
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 13
過去 30 日: 63
今までの合計 6,605
1件のコメント
I'm having the same issue. Iv change the sensor, and three weeks ago I changed the thermostat to a winter one.. how after I changed that out the temperature didn't really move or make to much of a difference.. in the way it would warm up.. and as of today the fans are going . Like the motor is over heating.. iv looked at the ohm's to see if there was a break in the wires .. but that check is where it should be sitting.. I do believe 200 ohm's.. ?
lonly4 さんによる
