メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
630回答 すべてを表示
Device wont actively track Battery %
hey team! ive encountered an issue.
Theres an iPad im trying to fix that has an issue with actively readying the battery.
if the battery is at say 54% hypothetically when i turn the device on, it will not read another battery level, but if i turn the device off, then on again, it will read a new battery level.
I tried 2 new charge ports, and a new battery.
I would prefer to keep the data if at all possible, though i am aware there is potential that it could be software reload time. this is my last resort, and would like to try other things (boardwork) first.
Please answer if you have seen this issue before.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Scott , Just a thought, could you just not install a free battery app something like one below.
https://itunes.apple.com/us/app/battery-...
さんによる
3UTools if you want to check battery information via computer.
さんによる
i would like to learn how to fix it. thanks though.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi Scott. Do you know if the battery you used to test is "known-good"?
Have you checked FL7500, right next to the battery connector? It is the only thing inline between the battery gas gauge and it's ultimate destination, the PMIC and the CPU. Normally a bad or missing FL7500 causes erratic readings but that would certainly be the right thing to check in your case.
Verify it's presence, good electrical connection and measure its resistance. At DC levels, it should read essentially zero. It only becomes resistive at high frequency to filter out noise.
Otherwise, you should do a full restore to eliminate any software issues.
UPDATE
Hopefully for you, the missing pad is the one in the red square. You can easily jump it to the cap right next to it or the connector pin. If it is the blue circle, well then you will have to very delicately scrape the board to get some of the copper via because it connects directly to the CPU and PMIC.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
if you could post an image of the board, and highlight its location, so i can do as suggested, or a schematic for me to read, i would appreciate it.
さんによる
The schematic is widely available on the web. You may need to sign up to GSM-Forum. This is a very tiny component...do you have the right tools to do this?
さんによる
i do board work on Samsungs regularily, im assuming it will be similar to that.
さんによる
Yeah, then no worries. It's a 0201 SMD component.
さんによる
component is not present. one of the traces are missing. do you know where i could jump the lead to?
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 379
