Gear shift indicator/odometer stays visible with engine off.
With the gear shift indicator/odometer staying on all the time, this causes a parasitic draw. Is there a relay that controls this function or would it be in the circuit board?
kenwhitlock1 , Check under hood for wire harness excessively wet or corroded around connections and fuse box. If all looks good, from a lot of forums I checked, it could be a problem with the (GEM) Generic Electronic Module. Locate the GEM (link #1) and check it for excess moisture/corrosion/connection also. Test can be ran by a good Technician to check circuits going to GEM to see if it is bad. Link #2 mentions a TSB on a like problem also.Good luck.
このアンサーは役に立ちましたか?
Thank you very much for your response. Not only the response but the supporting documentation and video. You've been very helpful.
kenwhitlock1, Your welcome. Thanks for replying back and have a good day..
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 3,285
