Will I need a new windows 10 key?
I bought an asus s500ca without a hard drive I'm hoping to use a usb boot I downloaded from Microsoft and I was wondering if when I boot it up with this usb will I need to enter a new product key?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
What operating system originally came with this laptop? Both Windows 10 and 8 in later models had keys embedded in the motherboard. When you install, it will self activate with those keys.
このアンサーは役に立ちましたか?
I'm here to second that. I work in PC repair and if it is a Windows 8 or above PC with an embedded key it should just activate.
It should let you skip applying a serial code. It will notify you continuously though. There are some sites that give out codes (cant post here). Be wary on such sites as many are a bit sketchy
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 559
