メインコンテンツにスキップ
2014年10月16に発表されました。モデル番号はA1347でEMC番号は2840です。
PCIE SSD DIY in Mac Mini purchased in 2017
i have recently purchased a mac mini in jan 2017 from apple. I try to add a pcie ssd myself by getting ssd cable and a pcie ssd from an old mini 2014 ( which is a 32/24GB of toshiba ssd).
Unfortunately, the ssd is not detected in the mac os.
can any expert shed me some light? is the "new" boot firmware of mac mini 2014 not supported? do i need a very new apple pcie ssd?
thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Can you take some pics of the labels on the SSD and post them here so we can review what you have. It would be helpful understanding how you did the transfer and why. Was the other system dead?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Apple has not altered things within this series.
So what worked in the first systems of this series (2014) still works in the current models of this series presently.
Are you sure you didn't damage or forget something in the process or have a known good (correct) SSD?
I have quite a few of these in our office and I've moved the SSD drives around without any issues.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
thanks Dan. I finally figured out it was the cable issue. I ordered another one from another seller. The problem solved.
i cannot imagine it is due to the cable!
さんによる
Hi Jona, could you send the link where you bought the new cable? I have the same problem... the system does not recognize my SSD and i think the cable could be the problem, the guy who sells the SSD to me says it is a cable problem... so i want to try a new cable before return with de SSD. I am trying to use a 256GB Toshiba SSD
さんによる
I get my cables from PowerBook Medic:
- Flex cable for the 2.5" SATA HDD for the Mac Mini
- Flex cable for the Blade SSD for the Mac Mini 2014
You may want to review this if you are planing on using the blade SSD connection: The Ultimate Guide to Apple’s Proprietary SSD's
さんによる
コメントを追加
回答を追加する
jona さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 1,123
