Motor runs way too fast but has no power, stops when in contact with b
Motor winds up faster than normal but has no power. Stops as soon as it has any resistance. I can still hear the motor humming. Brushes seem to be free moving.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@cajamadi ,Peter, Sounds like the center hub retaining bolt may of came loose or hub may have cracked/stripped not holding tight on shaft. Disassembly guide link below may help in diagnosing your issue with the sander. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 227
