メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Bose 3-2-1 Home Entertainment System is a series of DVD-based home media systems in the Bose 2.1 home theater line. The Bose 3-2-1 Home Entertainment System was sold between 2001 and 2006 and was available in black and graphite colors.
System overload light is on
My system overload light is on and I can't get it to turn on what do I look for I can't see any fuse
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@albertchastine , Albert, You can try a reset. Info. from BOSE.
To reset your system, follow these steps:
-Turn the system off
-Unplug the Acoustimass® module power cord from the power outlet
-Wait 60 seconds
-Plug the Acoustimass module power cord into a working power outlet
-Turn the system on
I do not own this system, but have something perhaps you can try.Turn all volume down, unplug the system and any other devices, speakers,etc., plug back in and see if light is out, if it is, plug each device in one at a time to see if it is a particular component/socket causing overload light to come on.
If system still under warranty, return for repair/replacement/refund.
Contact BOSE at the last link below for recommendations. Good luck.
http://worldwide.bose.com/axa/assets/pdf...
http://worldwide.bose.com/productsupport...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Albert chastine さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 234
