メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
Engine bolt Tapping vs. Heli coil
Where the lower mounting bolt mounts my starter to engine has stripped threads. Some people say to drill it, tap it, and use a heli coil. I dont know why just tapping the hole and using a bit bigger bolt wouldn't be good enough. Would it be or not be good enough to mount the starter and why?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I assume that they don't suggest a bigger bolt because you might have to alter the starter housing itself, and drill a bigger hole in it to fit the bigger bolt. That could compromise the structural integrity of the starter mounting plate, and lead to it breaking. That is just an assumption though. Others may have a different opinion.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Good answer! Yes, thats the reason.
You don't want to use the wrong sized bolt as the clearance within the mount of the starter would need to be altered weakening the wall and its alignment.
さんによる
コメントを追加
回答を追加する
Tricia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 199
