replace charger port on samsung
charger port wont work
soul524 the charging port is soldered to the motherboard. you will have to disassemble your phone and replace the port. This video is almost identical to the way you will have to repair your phone. Replacement ports are available at places like this.
このアンサーは役に立ちましたか?
soul524 around $10USD if you buy the ports from places like this. Use this video for your repair.
このアンサーは役に立ちましたか?
@oldturkey03 , Just thought this was a little strange, maybe was it to be addition to your original answer?
From my experience the core prime has a slightly different micro USB port, there is a raised section in the port which requires a charge cable with the corresponding relief.
Or the port is totally dead
このアンサーは役に立ちましたか?
I will be getting an android phone but the charger port is blown how can I get it fixed
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 205
