メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
iPod Won't Turn on
My son has an iPod and it recently stopped accepting a charge. I've taken apart many devices before but wasn't sure where to start with figuring out what is wrong with this one. I figured taking it apart and putting it back together would be a good start (especially since he is a young kid and has likely dropped it a few times). Any suggestions or guides for how to diagnose?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Replacing the battery would be a good first step however it does require soldering. There is no specific guide to replacing the battery but you can use this one nonetheless.
If the battery doesn't solve the problem, then you likely have a defective charging circuit on the logic board. This can be caused by using non-genuine chargers.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I think this will likely be the next step I take, thank you for your help and I will let you know if it works.
さんによる
コメントを追加
Does the charging port cable plug in fully without gap?
If not clean out blockage inside port with toothpick or equivilant.
Make sure to avoid touching the 5 charging pins in the port. They can only be pushed down and not pushed to the side.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Sorry for taking so long to get back. Unfortunately that didn't help. Thank you though!
さんによる
コメントを追加
回答を追加する
armytrixter85 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 253
