メインコンテンツにスキップ
Flash unit for use with Nikon Cameras
11回答 すべてを表示
Corroded battery flash no longer operates
I have 2 nikon flash units. SB 600 and SB 800
Both sat for 3 years and the batteries corroded. I cleaned the battery cntacts and the SB 80 will turn on but will not fire. The 600 is a paperweight. I have not cleaned internally. Is there a tek?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
Awesome!!!! Rubbing Alcohol & Vinegar Worked great on my SB-5000.
さんによる
I used rubbing alcohol and vinegar as well on my SB-700 along with pencil eraser and Q-Tips...It cleaned up the corroded contact
さんによる
コメントを追加
1 件の回答
選択されたソリューション
@ericofmemphis, Eric, May need a good quality set of new batteries. Try this to clean the contacts on your flash one more time to ensure good contact. The best commonly available thing to clean the camera battery corroded contacts with is distilled vinegar and Q tip/cloth/small brush then very light polish with extra fine steel wool or an ink eraser on a pen, followed by a little 90% isopropyl alcohol on a clean cloth. Then dry the contacts with a dry clean cloth. You want to avoid using a cloth that will leave lint/dust behind. Finish by blowing out with a can of compressed air to get rid of any fibers or grit from polishing. Check the attached links dismantling and cleaning, instruction and guides, Good luck.
https://www.manualslib.com/manual/989223...
http://photorojo.blogspot.ca/2009/05/diy...
https://www.youtube.com/watch?v=SHbimNl7...
http://cleaning.lovetoknow.com/Clean_Alk...
https://www.youtube.com/watch?v=sDd4VkUm...
このアンサーは役に立ちましたか?
スコア 6
4 件のコメント:
Eric Thank you for posting your question and answer…I followed instructions of vinegar, alcohol and compressed air!! SB-600 is as good as new..
ALSO thank thankyou Google for finding this site!!!
さんによる
I had the exact same problem. Batteries corroded and the SB-600 wouldn’t come on anymore. I tried the alcohol and vinegar and its working again!! Thanks!
さんによる
found this 3 years later, thank you thank you thank you1
さんによる
Great advice!! I thought my speed light was toast and this fixed it good as new!! Thank you!!
さんによる
コメントを追加
回答を追加する
Eric Swartz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 55
今までの合計 5,953
