Oil Pan Gasket replacement
How do I remove the oil pan on a 2000 Mazda Protege 1.6 L to change the gasket?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Jesse Lippincott , The link below will give you free access to Protege LX L4-1.6L DOHC oil pan literature, pan install, torque specs.,etc. (just press the next to advance through the guide), or you could pick up a manual for yourself at most automotive shops or perhaps the local library. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 9
今までの合計 1,869
