picture color change color
after tv is on for about a half hour the color seems to change into a metalic type hue white clothes seem to have a gold metalic like shade in them
@gtracy06 it sounds like your screen becomes solarized which could be caused by a bad t-con board, a bad mainboard or even a bad panel. Pull up any onscreen menu. If the menu is clear but the picture solarized, it is most likely the mainboard that has failed. If both are solarized, it could be the T-con board or the panel. the only way to determine which it is you would have to replace the T-con board. If the picture remains solarized with a new T-con board then you have a bad panel.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 157
