メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
iPhone 7 Home button extension ribbon - Where to buy one?
Hi!
I have separated the lcd from my iPhone 7 but I was a bit to harsh on the little guy and I ripped the home button extension ribbon. Now I am having trouble to find a seller online. Does anyone have one for sale or know where to get one?
Does somebody also have a picture from the ribbon cable? The cable runs underneath the backlight so I can't get it out without damaging my working LCD. I am curious how it looks like. It would also help me out in looking for it online.
Anthony
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
7 件のコメント
https://www.etradesupply.com/apple-iphon...
they sell flex cable.. does anyone tried this?
さんによる
@ron2020 This part is absolutely useless, countless people have tried and verified.
さんによる
I was told once this cable is torn the home button will never work with the phone again due to a chip-pairing from the button to the phone - not even as a home button (let alone being used for Touch ID). Can anyone verify?
さんによる
Do you mean it doesn't help to replace it? Or that the product is poor value? @tomchai
さんによる
I’ve replaced my 7 plus ribbon cable once before. I ripped the original by accident while replacing the battery. I wasn’t sure on what the cable itself was called and I’m still not. So I ordered a really cheap lcd replacement kit and ruined it just for the cable. It restored the touch I.d and home button function. You have to have to original home button that came with the logic board. Otherwise you’ll only get that function back with the help of Apple
さんによる
2件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
Heres a teardown guide
iPhone 7 の分解
And heres the home button cable
[リンクされた製品が存在しない、もしくは無効: IF332-002-3]
Hope this helps
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I am looking for the EXTENSION ribbon cable. Not the Home button itself. It's one of the two cables that connect on the motherboard, the other one is a lCD+Touch cable.
さんによる
As you can see in the guide: https://d3nevzfk7ii3be.cloudfront.net/ig...
The bottom is the Home button extension cable, the above one is the lcd+touch cable. If I am correct the extension cable runs underneith the lightbox towards the home button. This part can't be found anywhere and there is no picture of it on the internet how it looks like, at all.
さんによる
コメントを追加
It's built into the screen, not a separate cable.
You have to buy a new screen.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
For practical purposes---it is part of the screen unlike earlier models. As of July 2017 the price of replacement LCDs are far cheaper than trying to McGuyver a screen to replace just the home button flex.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You can actually replace the home button extension cable but you'll need to desolder the backlight film from your lcd because if you don't , you'll lose fingerprint id . If you don't care for fingerprint, just replace the whole 3D touch + backlight film + home button assembly. This sits behind your lcd and is solderd to your lcd . You will desolder and re solder the new backlight into your lcd with the contacts underneath the backside of the lcd cable underneath black tape.
ALIEXPRESS SELLS THE IPHONE 7 3D TOUCH + HOME BUTTON Assembly for about $80. The whole screen will cost $350 +. So if your good with a soldering iron, you can save money.
"LCD Screen Display 3D Touch Film Module Part Flex Cable Ribbon Backlight Film Back Light Replacement For iPhone 7 / 7 plus 4.7""
I ripped this cable when disassembling, but worked after soldering new 3d touch assembly in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anthony さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 24
今までの合計 23,731
