courtesy light stays on while driving
interior light stays on while driving. doors closed
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
1. Verify that the courtesy light switch is in either the off or door position not the permanently on position.
2. Possible faulty door switch. (switch located in rubber boot in door frame, every door).
Try opening each door, one at a time, locate the switch and manually press the switch closed to see if there is any change at all to the light, even a flicker
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 22
今までの合計 1,821
