メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年10月22日発売。このモデルより、指紋認証「Touch ID」が搭載されています。
Weird Issue on startup
Hi Guys.
OK i have to say i have never seen anything like this before at startup.
It was doing this when it came into me & i did DFU reset which seemed to resolve the issue but after a couple of days (when the client came to collect it typically) it started doing it again.
the first part of the vid is in real time then i used same clip but slowed it right down.
Anyone seen this before or have any idea?
Thank is advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I haven't seen this before...usually I see the Apple logo bootloop.
That said, it does appear as though the boot process is interrupted pretty early on. There may (and I say may) be a logic board issue that is causing this failure. What I find odd is that you say it worked well for a few days after a DFU.
Is it recognized by iTunes or is it completely shutting down?
If iTunes sees the iPad it may be a LCD/Backlight issue. If not, then it could be another subsection that is pulling things down. If you have access to schematics and a multimeter, I would probe some power rails and visually inspect the logic board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kenny Leonard さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 15
今までの合計 173
