Bios animation start problem
Ive started my bios , configured stuff one by one restart after restart , then i clicked bios animated start and after saving changes and restart i get black screen , how to fix this for this model
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Make power is off.
Remove battery.
Press power button for about 10 seconds.
Put battery back in laptop.
Press and hold the F2 button , then press the power button.
DO NOT RELEASE the F2 button until the BIOS screen display.
Reverse that last BIOS setting you change - you don’t say what it was.
このアンサーは役に立ちましたか?
If you have black screen and you can't do anything, you should try reset BIOS. If it still doesn't work, there is probably one way to repair it - flashing BIOS.
このアンサーは役に立ちましたか?
I'm not such an skilled when it involves this just look at: https://creabiz.co/
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 516
1件のコメント
you cant go back to bios Menu ? Or just seeing black screen ?
Stifler Omega さんによる
