メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
Callers hear a buzzing sound?
Recently replaced my dock port assembly due to a speaker issue. Since then I've been told by callers that they hear an intermittent buzzing sound. I've re-opened the phone to make sure the gold metal prong near the mic is touching the chrome bezel and it is. What else could it be? Did I receive a bad dock port assembly? Help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
I have seen this problem before and it was caused by a bad mic and or connection on the dock. Try cleaning that connection with some isopropyl alcohol or replacing the mic only if you are confident in your soldering skills. Or try replacing the entire dock (again). Sounds like you are getting weird feed back from the mic. Good luck!
“You will not be punished for your anger; you will be punished by your anger.” - Buddha
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Interesting signatures to your answers--welcome to the team. Ralph
さんによる
Thanks so much! I'm trying that right now. Fingers crossed it works. :-)
さんによる
Well...IT WORKED!!!! I cleaned everything and made sure the gold prong was touching the bezel and put it all back together...works GREAT!!!! :-) Thanks again!
さんによる
Thanks glad to be on the team! I kinda like to let the geniuses speak thru me.
PS. Congrats on the successful fix!!!!
さんによる
コメントを追加
Umm does it work if I just clean the outer part of the speaker? My phone fell when I went in into a haunted house a few days ago and that is how the buzzing sound started what should I do I'm scared that if I repair it myself I will break my phone.. Any solutions?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carrie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,352
