メインコンテンツにスキップ
Guides and repair information for 49cc gas-powered scooters.
just will not start without a jump starter
replaced battery,new start,changedspark plug new coil drive belt replace cleaned filter changed oil last timeit started needed to use a jump starter drove it like that for months
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
So no kick start huh? Sounds like your battery isn't putting off enough cranking amps so you need to connect it to an external power supply to start the scooter (if I understand correctly). Try replacing the battery (again) with a high quality brand such as interstate. Also you may want to check your air to fuel ratio on your carburetor. Hope that helps.
"The 'Net is a waste of time, and that's exactly what's right about it." William Gibson.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
rchabonian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 2,876
