How do I edit or erase telephone lists
How do I edit or erase names and numbers from the telephone lists on a Blu Advance 4.0 ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
That works for the Blackberry. For the Blu 4.0, I discovered the method... go to contacts, touch and hold where the photo would be for that contact, a new half page screen will appear. Touch the figure at the top right of this new screen and a full page screen will appear. Then touch the three bars at the bottom left of the screen and a menu with options appears. From here you can edit or share, delete or set ring tone etc.
このアンサーは役に立ちましたか?
Go to the number or name in question in you contacts look for the little pencil in the upper right hand corner . This will allow you to edit the contact . Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 150
