No power after replacing lid switch
I replaced the lid switch. When I plugged the unit back it wouldn't power on. The green light inside on the board lights up, but that's it. Nothing else happens.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you are having problems with your washing machine’s lid switch, see the Kenmore 110 Series Washing Machine Doesn’t Stop Spinning When Lid Is Opened problem page for possible causes and solutions.
That switch is the #1 cause for it not to spin. I would go back in and check my repair and the wiring.
このアンサーは役に立ちましたか?
I checked the connection, I even tried plugging the old switch back in. I also tested for continuity on the new switch. I also double check the connections for everything else into the bacfk of the board. The only sign of life is a green light that comes on, on the back of the board inside the control panel. (Not visible without back panel removed )
James, I'm sorry, 'I'm at a loss on this one.
Hi,
Was the old switch faulty?
If not, and I know you said that you checked the connections, did you test for continuity from the switch to the control board as well?
With the power disconnected, remove the switch cable from the switch and using an Ohmmeter test between the two wires at the connector socket point back towards the board and see if there is a reading at all. If not identify the switch wires at the control board and prove each one from the switch connector.
Just a thought and if OK or you have done this apologies.
このアンサーは役に立ちましたか?
No apologies necessary, I did check the switch before ordering the new one. I have a feeling it's the control board. Found a refurbished one for not too expensive. If had I had to replace with new I'd have just bought a new washer for about $100 more.
過去 24時間: 2
過去 7 日: 3
過去 30 日: 24
今までの合計 1,387
2 件のコメント
What was going on before you fixed it?
mayer さんによる
The spin cycle wasn't working, and most of what I read said the lid switch.
James さんによる
