Why is my screen not working?
my screen is not working it cracked and now its not working its tweeking.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here is a link to the Ifixit guide on how to dis-assemble your tablet. It is helpful as it shows how to gain access to the LCD screen so that you can replace it.
RCA Voyager II RCT6773W22 Disassembly
New LCD screens are available online from places such as Amazon and Ebay.
Here are some examples. You may find others that suit you better, just search for RCT6773W22 LCD screen replacement part for results
https://www.amazon.com/Replacement-Displ...
http://www.ebay.com/itm/USA-New-LCD-Disp...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
How about you tell me how to fix the touch screen and make it work. There aren't any answeres. I'm not trying to fix the led light I want the touch screen to work
このアンサーは役に立ちましたか?
Basically the reason our touch screens are not working is because the are broken and the only way to fix them is to replace the part that controls the swipe on our screens. I see this problem with alot of the rca voyager so it must be a manufacture problem . I believe most of these come with a 1 year warranty so i am going to call the company and tell them to fix this . i guess you really get what you pay for . my apple never had any problems had for years this is my sons for 5 months and broke
Hi @mandi060911 ,
My answer was to a question regarding problems with a LCD screen for this tablet and how to fix it (by replacing it), not problems with the digitizer (touchscreen). Also I'm not quite sure what you mean about the led light. My answer was never about fixing the led light. What led light are you referring to?
If you had looked through the guide in the answer you would have found from Step.16 onwards, that it shows the digitizer, so that you could have access to remove it and replace it. The answer you wanted, which you couldn't find was there.
Here is a link to just one supplier of the part. It is not a recommendation to use them, it is just shown to give an idea of the cost of the part. There are others online that may suit you better. Just search for RCT6773W22 digitizer part.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 9
過去 30 日: 11
今までの合計 2,463
