Roomba Runs for a minute and shuts off
Purchased new battery, fully charged, but only runs for a minute
RoombaQueen , Maybe try the battery reset procedure to see if that corrects your issue, you may have to repeat this procedure a few times. See link below on how to reset. Good luck.
このアンサーは役に立ちましたか?
Thank you GREAT video help
My 900 series will run for a minute then stop with 4 rising tones - battery is fully charged but its in a vacation home and the temperature is cold, could that stop it? its above freezing but prob in the 40's.
過去 24時間: 2
過去 7 日: 4
過去 30 日: 19
今までの合計 10,513
3 件のコメント
Does it make any noises when it turns off? Does it beep? If so, how many times does it beep?
Geoff Ice さんによる
No, it just stops. But it's working now! I unplugged it for a few months, plugged it back in to charge, and it works. No clue what happened. Thank you
RoombaQueen さんによる
Hello
Just replace the battery fully charged hit the clean button runs for a couple of minutes and it stops the status light shows up red and the clean button keeps on flashing green Thanks for your help
Giuseppe Cusano さんによる
