メインコンテンツにスキップ
Released July 24, 2014, Amazon's Fire Phone is Amazon's first smartphone, designed to compete with iOS, Android, and Windows Phone devices.
Wifi signal weak after battery change
After replacing battery in amazon fire phone, I was unable to connect to wifi weak signal. it pick up signal only within 1 foot from router range. And also not full signal..
any suggestion what I did wrong during battery replacement process.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
This is just a guess after looking at the tear down on Ifixit. I would be looking at the flat antenna connections and making sure they didn't come loose. It looks like you could easily catch the antenna cable with the adhesive strip you pull out from under the battery.
さんによる
you are talkin about the black strip cable...
さんによる
I have this problem too. Can anyone solve it for me?
さんによる
I check all the strips also antenna cable which is perfect, not loose but facing same problem very weak signal of wifi and Bluetooth this all due to replacing my fire phone battery.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
Here is a link to the Ifixit teardown for your phone.
In Step 7. of the teardown it mentions flat antenna cables, just after removing the battery. Perhaps you loosened their connections when you removed the battery.
Amazon Fire Phone Teardown
Hopefully this is of some help.
Update (02/03/2017)
Hi,
Here is an image showing the actual connectors. Check that they are both OK.
(Click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 5
19 件のコメント:
Haha. I was just commenting about the antenna cables. I must have clicked on the question just before you answered, and my screen hadn't refreshed.
さんによる
or the golden strip you are talking about
さんによる
Hi, It may be both as it mentions cables (more than one)
さんによる
I checked it all the way.. black strip and golden strip are tightly inserted...
さんによる
again tighten the black trip...but no success. wifi signal bar some time flicker..and jump to full signal but all sudden drop.
さんによる
14件以上のコメントを表示
コメントを追加
回答を追加する
Khurram Shahzad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 3,315
