メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Brake light stop working
Brake light stop working on my truck i put a fuse in it and hit the brakes and it blew put other one in and it done the samething what do i do
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi, Does it only happen with the brake lights or do you blow a fuse with the tail and turn lights as well?
Have you got trailer wiring connected at all?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Patricia Holloway, If your brake light fuse is blowing every time you press the brake pedal there is a dead short in the brake light circuit between the switch and the bulbs. The wire harness must be traced to find the short. Try a visual inspection, you will be looking for any damaged,bare,pinched,burnt(melted insulation) on wires,plugs,sockets and also check/test bulbs. Pay special attention to any where wire could be rubbing on metal frame, taped up joints/connections, etc.. If there is a trailer light harness with converter, especially if a add on one you may want to disconnect it as they can be problematic and cause this issue. If not comfortable working on your vehicle take into a good shop and have them diagnose and estimate repair, most good shops have hand held short finders(link below) and can find the problem fairly quickly. Good luck.
https://www.youtube.com/watch?v=ufVuWznm...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Patricia Holloway さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 91
