メインコンテンツにスキップ
Released in August 2016, the DTEK50 is the second handheld launched by BlackBerry on the Android platform after the PRIV.
1回答 すべてを表示
Alcatel one Touch Idol 4 digitizer used on a dtek50?
Good evening,
DTEK50 digitizers are quite difficult to find.
Since the DTEK5 is essentially a rebranded Alcatel one touch idol 4, could those screens fit on a dtek50 ? The connectors appear to be the same and the dimensions + screen resolution seem to be identical.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I would think seeing they come off the same assembly line they should have interchangeable parts . I would give it a shot there not expensive but if the connector doesn't mate with ease I would not force the issue just in case. This is my opinion and it may not be correct but hey I'd try.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
I contacted a few suppliers to have the flex cables' length, just to compare with a DTEK50 cadavre I have . I had found one supplier, but he could not support the demand. And the price was almost double. Thanks for the advice mate.
Cheers!
さんによる
After testing an alcatel idol 4 digitizer on a dtek50, I can confirm this is a 100% compatible match. Thanks @jimfixer
さんによる
コメントを追加
Hi guys is the lcd for the alcatel idol 4 also compatible with the dtek50? emergency!!!!!!!!!!!!!!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, it is the same part. Tested from 3 different suppliers with the same result. It's positive, the part number on the idol 4 digitizer matches the original one extracted from a dtek50.
さんによる
コメントを追加
回答を追加する
coutureg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 905
