help me I need help
my screen wont turn on anymore how can i get it to turn on
この質問は役に立ちましたか?
@killerclownson ,nathan eastman , Make sure your device is charging or fully charged, try a different charger or cable if not sure it is charged or charging. You can try and hold the power button and volume down switch, a android logo should appear, then go into menu and select boot normally. Below are links that also help in getting your device to power up. Good luck.
このアンサーは役に立ちましたか?
it might work i have problems
過去 24時間: 0
過去 7 日: 0
過去 30 日: 18
今までの合計 128
